kuro99
Príspevkov: 2161
Správa zaslaná: 26. 10. 2016 o 11:30 | odkaz na príspevok
stanikg ~ kolektiv mas limitovatelny a vzdy aj bol per bank ako pise Timo. Min s non VBC to slo cez pitch krivku vzdy na 100% nastavit.
Tento parameter je primarne na potlacenie vzpinania (Anti Ballooning System).
Collective Balance
Adjustment for the Anti Ballooning System. Use lower values for Helis with high collective ranges and vice versa. (only with NEO available).
New parameter to adjust the real collective throw. Since NEO includes collective in the control loop already, this parameter allows to tell the control loop the effective collective angle.
Tak ako Swalko pise je to magicka velicina ktora ovplyvni mieru prekompenzacii v riadiacej slucke. Presne vysvetlenie bude asi dost krkolomne kedze aj Uli sa dost zdrzanlivo vyjadril na dopyt ludi z fora. V skratke nie je to az tak dolezita velicina a efektivna je len pre extremne nastavenia. Velky kolektiv, tipujem 14+ pouzivaju takmer vylucne rychlostne heliny. Na 3D toto nema zmysel.
No its not linear, but the settings are not very critical. If you calcualte it as you did, its good enough. Usually its only needed to adjust something here if you go to the extremes on both ends.
so long ... Uli
http://www.vstabi.de
1 2 3 4 5
Online za posledných 5 minút: RedBaron,
