Fejts
Príspevkov: 51
Správa zaslaná: 23. 11. 2017 o 23:38 | odkaz na príspevok
Nazdar,
idem si dopriať vianočný dáreček a kedže som v koptérach čistý amatér (lietam iba s Eachine E010) tak by som potreboval troška poradiť. No, nastal čas na niečo väčšieho...
Holybro Kakute F4
https://www.aliexpress.com/item/Holybro-Kakute-F4-AIO-Flight-Controller-STM32-F405-MCU-Integrated-PDB-OSD-for-RC-Drones-With/32818635976.html
Racerstar RS30A
https://www.aliexpress.com/item/2016-New-Arrival-4PCS-Racerstar-RS30A-Lite-30A-Blheli-S-BB1-2-4S-Brushless-ESC-For/32763207751.html
Racerstar BR2205 2600KV
https://www.aliexpress.com/item/High-Quality-4pcs-Racerstar-Racing-Edition-2205-BR2205-2600KV-2-4S-Brushless-Motor-CW-CCW-For/32706224748.html
Martian II 220mm
https://www.aliexpress.com/item/REPTILE-Martian-190MM-230MM-255MM-4-Axis-Carbon-Fiber-Racing-Quadcopter-Frame-with-Power-Distribution-Board/32595899994.html
Eachine TX526
https://www.aliexpress.com/item/Eachine-TX526-5-8G-40CH-25MW-200MW-600MW-Switchable-AV-Wireless-FPV-Transmitter-RP-SMA-Female/32792637330.html
Foxeer XAT600M
https://www.aliexpress.com/item/Foxeer-XAT600M-HS1177-600TVL-CCD-2-8MM-Lens-IR-Mini-FPV-Camera-5V-17V-With-Bracket/32666863055.html
Kingkong 5045
https://www.aliexpress.com/item/10-Pairs-Kingkong-5045-5x4-5-Inch-Bullnose-PC-Fiberglass-Propellers-CW-CCW/32595453776.html
DYS FPV 5.8G
https://www.aliexpress.com/item/Hot-New-DYS-FPV-5-8G-Antenna-4dBi-Mushroom-Antenna-RHCP-TX-RX-SMA-RP-SMA/32698155644.html
A kedže nemám okuliare, nabíjačku a ani vysielačku ↓
Eachine EV800
https://www.aliexpress.com/item/New-Arrival-Eachine-EV800-5-Inches-800x480-FPV-Video-Goggles-5-8G-40CH-Raceband-Auto-Searching/32739150206.html
IMAX B6 MINI
https://www.aliexpress.com/item/Free-Shipping-SKYRC-IMAX-B6-MINI-Model-Aircraft-Balance-Charger-Discharger-For-RC-Battery-Charge/32250724672.html
Flysky FS-i6 + FS-iA6B prijímač
https://www.aliexpress.com/item/Flysky-FS-i6-FS-I6-2-4G-6ch-RC-Transmitter-Controller-wvith-FS-iA6-Receiver-For/32630763392.html
Za každú pripomienku, radu budem nesmierne vďačný.
snail.fpv
Príspevkov: 300
Správa zaslaná: 24. 11. 2017 o 02:16 | odkaz na príspevok
na to ze si podla vlastnych slov amater a nevyznas sa tak si si vybral celkom dobre v ramci moznosti.. je to taky entry level quad ktory neurazi ale ani neohromi.. na prvy 5" to bude ok..
za mna co by som urcite vymenil tak:
Motory - ked tieto tak si kup aj do zasoby - lubia sa velmi rychlo poohybat.. mozes ist do tychto ale mozno by som skor odporucil nejake EMAXy, nie su moc drahe a vydrzia toho urcite viac
regle - ked uz racerstar tak aspon tie V2 (alebo skus kuknut na rotorame nieco.. na tie motory ti bohate postacia aj 20A regle)
VTX - aspon EWRF alebo idelane vyuzi akciu na rotorame a kup si TBS Unify race za 20e. ked budes lietat s dalsimi ludmi podakuju ti ze nemas VTX s ktorym ich budes rusit a zhadzovat z oblohy
Kamera - kamera su tvoje oci, ked nahovno vidis, nahovno lietas. tu nesetri.. odporucam rozhodne RUNCAM SWIFT2 !! dovod tu >
No kedze vlastnim obe, mozem povedat ze rozdiel je dost dramaticky.
Sam som bol najskor proFoxeer lebo som mal ArrowV2 2 kusy aj V3 a bol som spoko. Potom som si povedal, ze skusim swift2 a sklamal som sa. Problem bol vsak v tom ze seom mal zrejme vadny kus alebo som ju poskodil hned na zaciatku nejako ale v protisvetle mi blikal obraz do oranzova. Potom som poskusal vselico (Eagle2-tragedia, Owl2- na vecer a na noc uplna fantazia, cez den slabsi priemer, flashovala ako Eagle2) a nakoniec som opat skusil Swift2 a v tom momente u mna Foxeer skoncil.
Dovody su nasledovne:
- 2.5 cocka na Swifte - malicka menej nachylna na poskodenie a nema take poduskovite skreslenie ako maly 2.5mm od foxeeru(kto chce wow factor moze si tam prasknut RC25G (ak foxeer HQ)
- spracovanie obrazu ma Swift daleko lepsie ako arrow, hlavne protisvetlo. Na arrowe mas napr od slnka vertikalnu ciaru cez cely obraz, na swifte som nic take nebadal.
- moje arrowy su ovela viac nachylne na odlesky ale to je sposobene tym ze maju HD cocky s velkym prednym elementom.
- zaepoxidovany senzor. ArrowV2 nema nic, ArrowV3 ma nieco ale vyzera to viac ako hotglue nez epoxy.
- mensie telo (zadna stena je vnorena do tela (foxeer ma zadny kry co kameru predlzuje o cca 1mm - blbost ale v tesnom builde pomoze ked tam nechces riesit mini alebo mikro kameru)
- vaha 12g Swift2 vs. 16g ArrowV3 (aj V2 co ma prave prekvapilo dost nakolko ma V3 oproti V2 kovove telo.. mam ich vsetky 3 prave vedla seba na stole)
- detail ale spomeniem - OSD kabel Runcam odpojitelny, foxeer napevno v konektore
- rozdiel je v umiestneni otvorov na mikrofon a samotnych mikrofonov na doske - swift2 zozadu, arrowV2 spredu, arrowV3 otvor na tele nema ale mikrofon ma rovnako spredu ako v2 kedze je to aj na pohlad ta ista doska, a podla toho ako sa chovaju aj ten isty FW
Rám - ok.. mozno si k nemu dokup rovno aj nahradne diely alebo kup tie ramy rovno 2.
Vrtule - kingkongy budes lamat jedna radost takze bud si ich nakup poriadnu zasobu alebo chod do tzv durable props, napr HQ - 5x4,3x3 velmi dobry a osvedceny model lieta ich velmi vela ludi takze sa kludne popytaj.. su sice drahsie v porovnani s kingkongami ale to je skor by som povedal parodia na vrtule..
nepisal si ako ta limituju financie... ked som zacinal tiez som sa obzeral po najlacnejich variantach az som nakoniec kupil tusim za 100e lietany quad a za podobnu sumu wizarda220.. (wizard boli vyhodene peniaze) nastastie skladacka posluzila na naucenie ale casom aj tak skoncis pri niecom kvalitnom.. pri FPV plati na 300% - kupuj lacno kupuj (prinajmensom) dvakrat...
Pokial pojdes hned na uvod do niecoho sice drahsieho ale kvalitneho, jednak sa ti bude lepsie lietat, budes mat tym padom rychlejsi progres a hlavne ten quad aj nieco vydrzi...
pokila by si chcel poradit fakt kvalitu tak sem hod svoju predstavu o cene a mozme skusit nieco zbuchat sudiac podla tvojho prvotneho vyberu ako novacika vidim ze si vies spocitat 2+2 takze toto vlakno vidim ako priestor na celkom rozumnu debatu
vela zdaru
Príspevkov: 868
Správa zaslaná: 24. 11. 2017 o 09:51 | odkaz na príspevok
bolo nutne to az takto natiahnut? nestacilo napisat zoznam komponentov? toto rozhodne lustit nebudem
co sa tyka prveho prispevku tak Snail to vystihol uplne presne.
Len doplnim k nabijacke, pokial nepotrebujes nabijat v terene a staci ti AC napajanie mozno by som uvazoval o Accucell S60 z HK: https://hobbyking.com/en_us/accuell-s60-ac-charger-eu-plug.html
snail.fpv
Príspevkov: 300
Správa zaslaná: 24. 11. 2017 o 10:43 | odkaz na príspevok
kralcikandrej:
ja som objedna totok prajem príjemné čítanie
No a takto to dopadne ked niekto objenda skor ako sa poradi... budes kupovat 2 krat.. [btw skus ten pripeveok editnut nech tu nesvieti na pol strany plny zbytocnosti a nepodstatnych informacii-slo by to aj na 10 riadkov ]
Fejts spravil dobre ze sa najskor opytal
K tej nabijacke suhlas s Jurajom.. to by som z aliexpresu nebral.. bude to na 99% fake a nestoji ti za to aby ti horeli doma lipolky.. nabijacku to chce kvalitnu. takze bude co ti dal on alebo potom zdroj + nieco od ISDT, pripadne skyRC.. idealne iCharger ale to sme zas v inej cenovej..
Príspevkov: 868
Správa zaslaná: 24. 11. 2017 o 10:52 | odkaz na príspevok
ja som dal ten accucell lebo stale nevieme aky rozpocet je k dispozicii
radio ja osobne by som volil radsej toto, aj som zvolil
https://hobbyking.com/en_us/turnigy-evolution-fpv-radio-mode-2-white.html
Fejts
Príspevkov: 51
Správa zaslaná: 24. 11. 2017 o 11:17 | odkaz na príspevok
Dík za príspevky, všetko informácie som prijal no je tu jeden problém.
Chcel som to skladať so všetkým (okrem batérii) do cca 280€ (samotný dron, radio, okuliare, nabijačka) no a s týmto čo vidíte v prvom príspevku som už mierne za (ali cca 290€+-) Rád by som zobral všetko čo mi odporúčate no potreboval by som do toho narvať ďalších 100€ čo je už moc.
snail.fpv
Príspevkov: 300
Správa zaslaná: 24. 11. 2017 o 11:26 | odkaz na príspevok
Ok dobre ze mame rozpocet.. aj za 280 sa nieco snad bude dat zlozit. Vecer si k tomj mozem skusit sadnut a dat nieco dokopy lebo co si si vybral rak ako som pisal nie je to uplna tragedia ale aj za 280 sa bude dat poskladat nieco vhodnejsie
Príspevkov: 868
popozeraj si ceny na banggood.com - vseobecne odporucam viac ako ali (moj nazor)
skus spravit objednavku a pouzit kod "toysho" to by ti mohlo dat 8% dole z ceny.
napriklad EV800 na Ali z tvojho linku za 80$ a banggood ich ponuka za 52$ aktualne
Fejts
Príspevkov: 51
Správa zaslaná: 24. 11. 2017 o 11:41 | odkaz na príspevok
Banggood? OK, beriem na vedomie, počkám teda na setup od snaila Dík moc!
Príspevkov: 868
Správa zaslaná: 24. 11. 2017 o 11:57 | odkaz na príspevok
tu mas narychlo nieco odo mna, ceny v eurach:
Banggood
Ram: MartianII - 22.30
Motory: BrotherHobby R2 2205 - 49.52 - EMAX niesu aktualne skladom tak som dal cenovo podobne aj kvalitou snad dobre
ESC: RacerStar 30A V2 - 40.15
FC: Holybro Kakute F4 - 34.17 - iba priklad, moznosti je vela, napr HK ma momentalne akciu na RF Revolt za cca 25Eur, ale budes potrebovat potom este PDB cca +12Eur
Kamera: RunCam Swift2 2.5mm - 34.16
Okuliare: Eachine EV800 - 45.27
Rotorama
VTx: TBS Unify Pro Race - 20.00
HobbyKing
Nabijacka: Accucell S60 - 20.00
Radio Turnigy Evo: 50
spolu: 315.57 bez baterii
vies usetrit na kamere a lacnejsom vtx - sam mam toto aktualne
ale casom budes urcite menit, tak ci je to setrenie na nespravnom mieste
VTX: Eachine VTX03 - 8.53
Cam: Eachine TVL1000 - 9.39
chemistt
Príspevkov: 363
Správa zaslaná: 24. 11. 2017 o 13:36 | odkaz na príspevok
tiez som akurat objednal ale zobral som obycajny nie race
Neviem velmi ci usetris aktualne ked na to nemas tak je to fajn ale ja som uz 2 VTX odpalil pretoze som odbil antenu. To boli stare FTcka. to je hned 30 Euro + novy dalsi je 10 Euro to mas hned 40.
Tieto TBSka sa chvalia tym ze vydrzia bez anteny aj hodinu. Potom je velka vyhoda pit-mode a smart audio. Pit-mode robi to ze pri starte nastavi vysielaci vykon na 0.x mW takze ak zapnes copteru v okoli ludi co lietaju tak ich nerusis.
Príspevkov: 868
Správa zaslaná: 24. 11. 2017 o 14:05 | odkaz na príspevok
smart audio ma vyznam len pri taranise, pokial s tym nelieta race a nepotrebuje kazdu chvilu menit kanal a vykon tak sa bez toho zaobide.
hlavne nebrat V2 V3 tych TBS VTx tie maju striktne dane 5V napajanie.
na vtx je dobre dat pigtail a az potom antenu, v pripade ulomenia anteny vdaka pigtailu neodpali vtx, par anten som uz polamal a koptera lezala aj 30min kym som ju nasiel so zapnutym vtx a bez ujmy
snail.fpv
Príspevkov: 300
Správa zaslaná: 24. 11. 2017 o 14:21 | odkaz na príspevok
no Juraj ma predbehol.. asi by som nic lepsie dokopy nedal.. len doplnim.. EMAX2205 su skladom (sice len CW verzia ale ako vieme problem to nie je, vsetky kvalitnejsie motory su aj tak uz len CW vacsinou) https://www.banggood.com/Emax-RS2205-2300-Racing-Edition-CWCCW-Motor-For-FPV-Multicopter-p-1028793.html
Regle a Ram suhlas.. (+2 ramena nebudu na skodu ale to v konecnom dosledku by bolo najlepsie mat z kazdej suciastky aspon po jednej do zasoby ale chapem ze na uvod sa to neda.. do buducna na to mysli ale )
FC - ako pise Juraj kludne chod do revoltu z HK v kombinacii s nejakou matek PDB (kupis aj za 10e) vyjde ta to rovnako ako kakute ale ziskas moznost lietat Raceflight RF1, ktory je uzivatelsky ovela prijemnejsi z hladiska nastavenia a co je hlavne podla mna lieta neporovnatelne lepsie ako betaflight. (skusil som vsetky - kiss, bf aj rf) KISS lieta tiez fajn (lepsie ako BF) ale tam sa asi nedostanes na taku prijatelnu cenu
Radio - ja osobne by som v tomto pripade zostal pri klasickom flysky.. evolution ma udajne dost problemov s FS v porovnani s klasikou i6 (nemozem potvrdit, len reprodukujem co som sa v podslednej dobe docital.
K navrhnutym moznostiam na setrenie:
VTX rozhodne TBS Unify, pri aktualnej cene nie je co rozmyslat.. je to top kvalita co sa VTX tyka - sam som na jednom lietal s odpojenym pigtailom (este vacsi extrem ako bez anteny) prazil 200mW a lietal v pohode na ploche ponad 2 futbalove ihriska a ten VTX dodnes zije a dava aj 1.5km na 25mW ad.smartaudio (pokial by bral FC s OSD tak ho vie vyuzis s hocijakym radiom. V pripade revoltu je to tak ako pises.. taranis only.. bezi to aj na spektrume (dokonca lepsie jak na taranise) ale neviem ci by som siel do spektrumu..
Ked chces par eur usetrit tak to EWRF.. cokolvek ine by som zakazal pokial chces lietat aj s dalsimi ludmi
Kamera ako som pisal.. radsej kvalitu a vidis a lietas v pohod.. tu by som nesetril.
Moznost usetrenia vidim skor v najdeni bazarovych okuliarov, resp. nabijacky. (pri okuliaroch vsak plati to co pri kamere - cim lepsi obraz, tym lepsi pocit z lietania - avsak tu by sme prekrocili cely limi len okuliarmi.. ale ak ta to zacne bavit tak to bude zrejme tvoja prva velka investicia..stastie je ze kvalitne aj ked drahe okuliare si velmi dobre drzia cenu takze pri ich priapdnom predaji vela nestratis..to bolo ale len take vestecke okienko )
Príspevkov: 868
Správa zaslaná: 24. 11. 2017 o 14:36 | odkaz na príspevok
Pokial viem tak Turnigy Evo malo problem s FS len pri pouziti FS-A8S prijimaca, su ludia (zberaci gramov a setrici penazi) ktori to parovali prave s tymto prijimacom a FS nefungovalo. Ja sam to lietam, momentalne mam X6B a predtym IA6C a s FS ziadny problem.
FS-A8S mal byt porieseny v poslednom update.
Evo nieje ziadne top radio ale mna si ziskalo svojim tvarom, jednoduchostou a jasne ze cenou nevyhoda je vstavana antena a mensi dosah. Ale long range nejdes stavat skor ti zmizne video ako strati signal vysielac. Tie EV800 maju svoje limity.
*EMAX - pozeral som pack 4. kusov, preto som nevidel ze CW je dostupne, tak tu vies este par euro zhodit, cena je tusim 11Eur za kus
bazarove okuliare asi lacnejsie nebudu ako tych 45 za EV800 a nabijacka s cenou 20Eur z HK je tiez asi na cenovom dne
Aktualna cena KISS FC na HK je 23Eur - nizsie sa uz asi nedostanes
rozhodne by som vyberal medzi KISS a RF, Betaflight nesadol ani mne aj ked na tom lieta komplet ceska republika
snail.fpv
Príspevkov: 300
Správa zaslaná: 24. 11. 2017 o 15:09 | odkaz na príspevok
dakujem za objasnenie Flysky nelietam ani som nikdy nemal tak som nevedel dat 100%ne info..
jedine co si dovolim tvrdit opacne je ze skor vypadne video ako RX link.. to sa mi snad este nestalo.. na frsky som dalej ako 1km nezaletel a ako som pisal vyssie aj na 25mW som mal na 1.5km krasny obraz (aj ked tu je to uz asi skor vecou prijmaca na okuliaroch)
Osobne som evo v rukach este nedrzal ale aj klasika i6 mi na pocudovanie celkom padla do ruk.. a co ma na tom ake je to lacne radio prijemne prekvapilo je vstavana diverzita.. takto je tazko radit.. ono najlepsie by bolo pokial by si chytil do ruky ako evolution, tak i6 a sam by zistil co mu sadne do ruky lepsie.. ak pinchuje alebo je hybrid tak mi evo pride menej vhodne..
spomedzi KISS a RF by som pre zaciatocnika odporucal radsej RF.. je to mensi pain in the ass na nastavovanie (kiss nema passthrough na regle - pre mna dealbreaker pokial nekupujes orig kiss regle) v RF spravis par klikov a je to KISS je fasa ale aj ja sam som sa s nim spociatku natrapil statocne.. RF je viac plug'n'play riesenie..
  • 168 ľudí online za poslednych 5 minút.
Online za posledných 5 minút: bzuk3, martin-, mig29,
